13th Age Map
 JulianDracos
                Mapmaker
JulianDracos
                Mapmaker
            So I thought this was going to be an easy/quick map. But then I needed to draw a gorge and there was no symbols/terrain for it, so I have to do it myself. Then I needed to make another piece of land obviously higher, so I used a bezel. Later on, I was like, I can just use the contours. Those looked nice, but seemed off with the other land raised it. I should have just removed the bezel, but instead I raised the land for everything that needed to be.
And then I kept modifying from there . . .
Unless there is some issue or suggestions on how to improve, it, I think I am done after I add text.
![[Deleted User]](https://secure.gravatar.com/avatar/c75d9a245b74d9c59be0999ea81ca541/?default=https%3A%2F%2Fvanillicon.com%2F92add7f8c954488718110edc4896ad39_200.png&rating=g&size=200)
