Did the commands change?!?
I decided to play around with cc3+ to refamiliarize myself with the program, since it's been so long since I've used it.
I'm creating a simple regional map to get me back in the habit of dealing with the sheets and layers. I set up a terrain mountain sheet, to do a normal mountain contour, like I remember, only I forgot to click on the sheet when I started to make my mountain range contour. Not a problem, I've moved things around to different sheets so many times, it's like second nature...
Only I can't find the move to sheet command! I also see commands I've never seen before... quick move? Nonvisual Move? Stretch? Nonvisual stretch? Where's the simple Move to Sheet command?!?
It's almost as if I need to start from scratch and throw out everything I knew before. Has the manual been updated to include these?
Move to sheet is in the right click menu for the Display Speed Settings hourglass button - or the Sheets and Effects button.
Now I'm trying to work out how to round up all the new commands since you were last a regular user...
Note that while Sue is right that you can find it on the right click of Display speed button, the more common way to access it is to right click of the Sheets and Effects button.
I am guessing you just right clicked the wrong button. All of those commands are really old.
Oh I edited my comment at the same time you posted yours, Remy. Sorry!
Does that count as a ninja in reverse?
oh! See I remember it being part of the move command... which is why I was getting so frustrated! lol...
