Merge or remove an old account
I lost access to my old forum account years ago when I changed ISPs. Recently I found my old password for it but I have moved on and have a new account now.
Is there a way to merge or remove the old account?
    edited November 2022
    Yes. Remy Monsen should be able to help you. If you give him as many of the details as you can of your old account that would probably be useful. Probably best by PM, unless Remy indicates otherwise. His avatar name is "Monsen".
    The forum software doesn't have a merge feature unfortunately.
    However, I can remove your old account. However, if that old account has posted any messages, I would rather keep it around even if those comments are old to conserve the topic integrity, and instead just disable the account (and I can remove any detail from it if desired). Sounds OK?
    I'll need to know the username or email address of the old account to remove, and I'll also need proof that this actually your account. (Sending me a PM from it is fine)
