[WIP] City of Mar-Goth
Jeff B
Betatester 🖼️ 37 images Surveyor
I'm currently working on a new city and using a different style this time around. The city is based on information from the person I'm making the map for so I'm trying to get as many elements into the map as possible. I have posted 2 versions of the map one with out the key and one with the key. The key version needs the fonts tweaked but I'm looking to see if they way I want to do the text and key works for people if I get the font style and coloring the way I like it.
Comments and suggestions are welcome as always.
Here are the final versions of the project.
Any chance of putting this in the Atlas - it is a great city.
I think that can happen. I need to learn how to do a map like your Eden NSW map you just posted. I ran into memory issues again with this one. Really need to learn to make maps that are not resource hogs or make smaller maps with less detail.
I find that maps which use a lot of vector symbols run slower. I don't know if Monsen has something to add to this.
It's not so much running slow as I cannot export at a good resolution without using the large export option. No more city maps for awhile I need to do a bunch of dungeon maps by the end of the month.
"spanding" ? Is that a typo?
Thank You corrected in Gallery Version
