i made some more villages and names on the map above.
After that the Text letters appear to have a tilt. i repeat the @Ralf command to export as last time works fine to solve this problem.
Quote:
"That might be an indication of an export doing a second rendering pass with a little "hiccup". Try this:
Type EXPORTSETMPPP and hit enter. The command line will show you a number. If you haven't ever changed the setting before it will be 4000000 (four million). Type 40000000 (40 million) and hit enter, then try again."
But this time still with the error after the command. Interesting i dont change anything on layers settings, just happened after put some more names.
i dont change anything on settings from the first map uploaded here, and this new one.
just opened cc3 again and add some more towns and names @JimP
seems to glow or outter glow are causing this issue, cause when i turno off, problem disappear. also tryed edge stripping and drop shadow on the TEXT and nothing, then i turn on edge stripping + outter glow, and problem appear again :/
That's because the black in the texture underneath is the same color as the text. Try making the text a very dark grey instead of black.
Alternatively, make a copy of the text sheet, with all the same entities underneath the original, but no sheet effects. Then turn all the text on that sheet a different color, like a purple. You won't see it, as it's below the black text, but it will separate it from the black in the texture behind.
Beautiful map!
Did you do the sepia toning with effecct in CC3+? Or did you do some post-processing?
post processing on lightroom
finishing my new domain where shablov village is.
scales are wrong, 1 square = 50km
Cheers
How i can fix this issue?
Thank you
The only time, this may not fix it for you, I have had that was when under Text Properties, the angle wasn't o.o
outter glow off
Outer glow on
Used grey # 242 and worked fine.
Thank you
i dont know how to do a copy sheet, but works changing to dark grey.
final procuct, ready to print in A0 plotter <3
Cursed village, not on the map, but present in the scenario.
Cheers
