How do I turn off auto-rotate of buildings?
At least in some styles, when I go to place a building, the building starts to rotate to different orientations when I get near the road. Is there a way to stop that? As it is, I often have to place it away from the road and then use the move function to place it correctly.
Just turn off Smart tracking. It's available from the symbol options dialog you get when right clicking in the map when in the process of placing a symbol.
You can also optionally completely disable the smart symbols from the same dialog.
Thanks.
