Chart question
Ricko
🖼️ 106 images Mapmaker
Hello all,
how i can insert those charts, for example from this masterwork from Mr. Eric McNeal, on my map? (also my current desktop background).
I want to use on my current Budapest City map Overland
Thank you
Not sure exactly how his setup is, but it looks like he's just added two filled polygons to a sheet that is on top of everything else, and then added text and decorative symbols on top of that again. Probably 3 or 4 custom sheets. (background, text, symbols, border)
Mr @Monsen how i search tutorial about this technic?
If have another way i also apreciate. Just need a chart/frame to put legends inside as in the example.
Thank you
It's not really complicated, it's just a few sheets.
The closest I can get to a tutorial I know is the section on making numbered dungeon rooms in the Tome (Pages 293-295), and a bit simpler version in the User Manual on page 40 when I added the title for the tutorial map in such a box.
@Ricko Hasche Just add these sheets to the end of your sheet list.
TEXT BOX (for the text box)
TEXT BOX FRAME (for fancy frame stuff)
TEXT BOX CARTOUCHES (for fancy pics, compasses, scales)
TEXT BOX TEXT (for text)
Hope this helps
