'hide all' for sheets ?
                🖼️ 280 images Departed Legend - Rest in Peace
                    In layers I can 'hide all' when I want to check for what item is on what layer. I use it to check and see what is only on one layer. Sometimes I put forest on the text layer.
Is there a way to do this with the sheets dialog ?
I ask because I'm converting over 100 CC2 overland maps to CC3 overland style and I need a quick way to find what is on what sheet. Mainly I insert the old maps on sheet grid and layer temporary and then move them to the correct sheet and layer on the CC3 version.
Thanks,
Jim
Thanks,
Jim
If you have lots of stuff on the common sheet, you may want to go to common first and move all stuff here to another sheet, so you don't have to deal with these entities all the time.
Thanks.
