Error Message with Ancient Tombs Isometric Map Style
Hello,
I am trying to follow Ralf's Live Mapping: Ancient Tombs Isometric note for note. After pasting my 2D floorplan, I next went to the "3D Projection" button as directed. When I do this I receive the following error message: "Campaign Cartographer 3 does not understand the command: IPROJ." After exploring a bit, I see that I also get an error message with any of the 8 style specific buttons in the top left toolbar.
Any suggestions as to what I may be doing wrong? Thank you.
Do you have Perspectives 3 installed? It is required for those features.
That was it. My mistake for not being polished up on the different products. Incorrectly assumed it was just part of Dungeon Designer. Downloading now, to settle in for a relaxing evening of mapmaking. Thank you Monsen.
I don't think you actually need Perspectives to take advantage of the issue itself, since it comes with proper symbols for both walls and floors. But you need it to use the 3D projection command, and it also gives the advantage that you can draw additional isometric shapes manually.
