Using an old mappa harnica map in cc3+
I am trying to get back to work on a project I was forced to step back from for a few years and would like to continue working on it in cc3+. The issue is that the last time I worked on this I was using mappa harnica with cc2 pro. I can open the map in cc3+ but the fills are not displaying properly. Does anyone know how I can get the mappa harnica fills to work in cc3+ without either reinventing the wheel or trying to add similar cc3+ fills, if any?
MH maps used their own palette, and back in the CC2 days, there were no way to embed the palette into the drawing, the files relied on the custom palette being available in the CC2 with the name fcw32.pal.
Now, with CC3+ things are a bit easier with palette handling, so I recommend copying the ma palette into your CC3+ data directory, and naming it something else than the default, for example mh.pal. Then, you can simply load the palette by typing PALLOAD @mh.pal on the CC3+ command line to load the palette. (After doing that, you can also go into the drawing properties and attach the palette to the map, so you don't have to load it again for that particular map.
Any other ideas of how to add my palette to cc3+ so I can save it to the picture and not worry about it in the future?
But after PALLOAD came along, it became much easier to juggle multiple palettes.
As I said above, once you have the correct palette, just going into drawing properties and attaching it to the drawing will make that map allays use that palette. (Unless you manually load a new one with the PALLOAD command)
I followed the instructions (several times). New palette (harn.pal, downloaded from Roy Denton's website, the re-worked Mappa Harnica Tools) and installed in the CC3+ file along side the fcw32.pal. No change!
PALLOAD
right click
find the Harn.pal file
left click
open File/Drawing Properties/Click Attach to Drawing.
Save
Close Map
Re-open map
No Change!
What am I doing wrong?
Please do not double post, it serves no purpose except splitting the answers from those who might try to help you and just cause confusion.
As for the issue, after using PALLOAD and loading the file, bring up the palette dialog to make sure the palette were loaded properly. There are some cases when a palette can reset to the one already built-in to the drawing (or the default palette if none), if this happens before you attach the palette, then it won't really do anything. If the palette dialog reveals that the palette was not loaded (i.e. it just shows the default), try using PALLOAD again. (You'll probably also see it visually in the map if the palette is correct or not without going to the dialog, as the Harn maps do look quite weird with the default palette. The map visual should update when the palette is loaded) I did run into the issue myself right now when I had to run it twice.
I also recommend NOT having a fcw32.pal file in the data directory, as this file is then used instead of the default palette, affecting every map that doesn't have an attached palette. This can cause added confusion and complexity when working with the palette. This file is a relic from the time before maps could have attached palettes. Just rename it to custom.pal or something if you wish to keep it around, you can then load it with PALLOAD when needed.
