Exporting from Fractal Terraines?
It seems like the exports from Fractal Terraines is really low res. Is there a way to get better exports?
  • I'm still fairly new to it myself, so my answer might be contradicted by someone else. But I suspect the main answer is to work in a higher resolution. The default resolution is pretty low. In the World Settings, change the Editing Size to something larger. I use 4096 personally, but go with what your computer can handle.
    The demo version is limited to a very low resolution for exports and image files saves (on the order of 128 or so).
  • 9 days later
  • As a would be buyer and software developer, I cannot help but feel that this measure is a bit paranoid.
    I guess, it's a trial. But the trial, as it is, does not permit me to test Fractal Terrain in the use case I need it for.
    I am not going to give ProFantasy 39.99 on the off chance that Fractal Terrain is what I am looking for.
    So, I guess you need to ease up a bit, or expect to lose easy sales.
    Please note that our Satisfaction Guarantee also applies to Fractal Terrains. You can always return it for a full refund within 14-days. This should give you plenty of time to test it to your heart's content.
