Install CC3+
 Thiles Targon
                Newcomer
Thiles Targon
                Newcomer
            I recently purchase an upgrade to CC3+, through humble bumble I think... I have a bunch of products on my product page, including multiple copies of some products.
1) Does it matter what order I install the product in?
2) Is there a way to tell which products I have installed and which I have not?
3) for products I have multiple downloads / serial numbers for, does it matter which one I use?
If you already have a product the spare code can be gifted to someone else, as long as you haven't already registered it on your own account.
Make sure that the 'spare' codes really are duplicated copies of what you already have before you give them away, though.
Thanks for the quick responses!
I'm working through Monsen's instructions now
@Loopysue I don't know which I have used and which I have not used, which is a shame I have 3 copies of CC3+
The registration page on the Profantasy website will give you the answer as to what serial number or numbers you have used.
Cartographer's Collection 1
Cartographer's Collection 2
Battle Map and Floorplan Collection
World Builders Compendium
Don't specifically say they are for CC3+, so I can't be sure; although the Fractal Terrains file is called FT3+ so I'm guessing I'm good there
All versions of ft3 are stand alone programs.
These are all the newest bundles from the Humble Bundle campaigns, so they are all for CC3+. As Jim says, FT3+ is a stand-alone software anyway.
With the latest update the Help >About option from the menu should tell you which serial number you have used for your CC3+ install.
Thanks!
