Cant find Dungeons of Schley from menu window when making house interiors
Hi!
Im trying to make my first village complete but I dont know nothing how to create the houses when I make a floorplan. So I watched a tutorial video where I saw the dungeons of schley add-on and I thought could this help me start making the houses.
So have I installed dungeons of schley add-on to wrong direction or why it doesnt appear there?
Anyway I would like to get some help on making floorplans, such as videos or some sites!
Select new, a popup with a list for overland, dungeons, etc. shows up.
Select dungeons, decide settings myself, and click next.
Down at the bottom of the next window, you will see SS 4 Dungeons of Schley.
There is a Live Mapping session Ralf did in 2020 showing how to create a floorplan map from a city building here. If this is the one you have already watched, I will look for another one, but this one is probably the best and most appropriate for the style you are using.
Ok, thank you for helping me!
You're welcome :)
If you have any problems after watching that video, just say.
Thank you for helping but I still have this problem, I dont have the dungeons of schley add-on inside this circle so I cant make my floorplans.
In the tutorial video above, there was the dungeons of schley, but I just dont have it there.
I'm a bit confused now.
Have you installed Dungeons of Schley?
Yes I did install Dungeons of Schley. And thats why I asked have I installed the add-on to a wrong direction.
Im very helpless right here in this probelm right now. So could there be any answer to this problem...
Thanks for all your time helping me.
Ok. Try running all the installers again in repair mode, starting with CC3+ and ending with the most recent update. If that doesn't work, then its probably time to contact Tech Support. You can do that through your account page.
While you are doing this, ensure that you allow the installers to open CC3 at the end of the process if that is what they want to do. Not allowing it has been known to cause strange problems before.
I'll try that.
Sorry for double posting, but I found another site where theres another person with the exact same problem.
https://forum.profantasy.com/discussion/10853/random-questions-and-problems
I decided that if the probelm doesn't get solved, I trie dungeons of schley on other computer.
If you can't get it working correctly, the best path is to contact tech support and get some official help. You'll find the support form on your registered user pages.
Probelm solved! I'll use now the tutorial video above.
Thanks for all your help!
