Wizard template: Fixed sheet order
Is it possible to fix the sheet order when making a Wizard template? Drawing blanks in the ToUM and searching the forum alike.
Best Answer
Yes - it should be how you save it so long as it is the TEMPLATE, not the FCW, you are saving. It used to be that you had to have each sheet have an entity in the TEMPLATE layer, but I din't think this is necessary now.
Answers
No more '.' dot at the 0,0 location ? Interesting.
The need for a 0,0 point was removed some versions ago. There's still an entity on each sheet, but it is a special entity you won't see in your map.
