First Map
Hi Guys,
Well after a few starts and much learning I have managed to make a floorplan with which I am realtivly happy with (SS4 Schley style). It is the underground portion of a ruined outpost with a cave section attached. The stone the walls could be improved, but I'm not entirly sure how. I also still have a lot to learn with sheet effects. On now to start on the above ground section!
James
Looking nice. Some mighty thick walls there, lots of Umber Hulks in the area?
Your first map? Very well done :)
The best way to learn about sheet effects is to play with them and see what happens. That might sound like a messy way of getting to grips with them, but it is a really good way to learn what they do and don't do.
Thanks for the kind words. The exterior walls are 15 feet thick, maybe a little excessive
It's been a great learning experience, I know what I'm going to try and do differently next time (relocation out of the Umber Hulk Wildlife Safari Park being one thing
James
This is a great first map. Certainly much better than my first.
So I wasn't entirely happy with the first iteration so had another go, this time with the SS2 Dungeon A style.
Big thanks to Lorelei whose Temple of the Horned God Ruins inspired me (and helped me reverse engieneer some effects)
And of course Remy for the advice to move to a less Umber Hulk infested area :)
Looking good. Glad you found a safer area, or those Umber Hulks would have taken good advantage of those collapsed wall segments.
I agree with LoopySue. If this is your first map you are starting it off with a bang. It took me awhile to get lighting to the way I wanted it to be and you pulled it off in your first try. Congratulations!
