Using forest terrain with other symbols present. (CC3+)
So I'm creating my first map and have a question about the forest terrain tool. I have cities/towns/villages placed on the map already and I want to use the Mixed Forest terrain to select the entire area all at once but the trees cover up the settlements. Is there a setting that will make the trees not spawn on top of the settlement symbols?
In-game, the settlements are located in a dense forest so dropping a few trees here and there just wouldn't look right. I've tried making the forest a section at a time while placing the draw points around the settlement symbols, but the end result just looks sloppy. It would also be helpful if I could get the same thing to happen to avoid spawning tress under road paths.
