Tome of Ultimate Mapping City- drawing the bridge
Hello,
I have been following the Tome of Ultimate Mappings city creation tutorial and have arrived at drawing the bridge. Step 20 says "...draw a rectangle 70’ wide and 15’ tall using the Box tool."
Is there a way to draw rectangle of a specific size? I can get pretty close with just the mouse but not exact.
Thanks,
pabadger
If you set the SNAP to on, and have a 10ft grid with 2 snapping points, then you can interpret that as 7 grid squares by 1.5 grid squares. I'm not familiar with the passage there, but given the instructions I would presume you then move it into place.
Or just type the coordinates on the command line. Place the first corner normally with the mouse, then enter @70,15 on the command line for the second corner.
Thank you so much for your responses Loopysue and Monsen. Good stuff!
