European castle
![Joachim de Ravenbel](https://i216.photobucket.com/albums/cc13/JoachimDeRavenbel/th_jdr68_zps48992fbd.jpg)
Hi
After the oriental castle I turn my mind to a european medieval castle-like.
I got a lot inspired by real castles near my home (lucky me). The design is this time however entirely mine.
![image](http://i216.photobucket.com/albums/cc13/JoachimDeRavenbel/ThbSimpleKeep.jpg)
I'm not quite satisfied but am at a loss... Any idea? Thanks!
Edit : pic no more clickable, see below.
I've modified some scales and split the jpg in the four parts :
The handwriting is a bit difficult to read I think... it's like it was done with a really shaky hand :-)
I first drew the design on graph paper, using medieval models found on the net.
I scanned my sketch and imported the file in CC3 where I retraced it with splines.
The resulting outline was then exported as a PNG and worked with PhotoFiltre and Gimp.
At last the png was converted in a symbol. Do you? I thought it enhances the medieval touch. Do you think it would be better with some gothic like font?
I'm (over)proud to announce that I've finished a long to birth project : A Guide to Castle Riche-Guêt.
I hope you'll find it useful and am eager to get feedback because it's a first draft.
I hade to separate in two files because of the 1000 kb restriction and sincerely hope I don't abuse. There's a nicer one that weights 57 Mb though...
Enjoy!
@Kolyana It took long but I don't remember how long. It was done using technical drawing technics: construction lines, construction lines and more construction lines. They still lurk on a hidden sheet.
@Gandwarf What took time was the initial drawing on the head of the topic and converting it to POV-RAY. That took even more time because going 3D I noticed inconstencies that had to be corrected first. On my next project, I'll try to work in parallel.
Putting all in a text file took less than two days...
Did by the way someone find flaws in the text/maps ? Does anybody know if there's an english for *fenêtres à coussiège*
The last page in the PDF contains the word "monster" but should be "monsters" I think.
Thanks for the comment and I'd said I'm rather proud of the view you describe.
