Missing OPT Files when starting CC3+
Maybe I just need to uninstall the entire application and all patches and add-ons but I figured I'd give this a try first. When I start CC3+, I get three errors presented to me, then the application opens to the main screen. The errors are that three files appear to be missing. They are; CC2PER-General.opt, CC2PER-Houses.opt and CC2PER-Colors.opt. I've searched around the file system and I've not found a single .opt file for that matter. I was wondering perhaps if I didn't reload a patch or forgot to add something to the overall build.
Any thoughts?
Any thoughts?
You should be able to fix it by deleting the cc2per.dll file found in your CC3+ installation directory (c:\program files (x86)+ProFantasy\CC3Plus).
I just got this same error pertaining to CC2PER-General.opt and found this thread by a Google search.
Whatever is installing the file cc2per.dll, is out there live. I believe it is one of the annuals.
My suspicion is it is the 2019 Annual Install file.
I have done what this thread instructed and deleted cc2per.dll which corrected the issue.
Additionally had the warning Source file not found - Fcw32.mac when trying to install update 25 of CC3+ on windows 10.
I found that installing the current version of Perspective 3 is what's triggering this issue for me at the moment. I am glad its an easy fix.
Well, that fix is just for people NOT running the Perspectives add-on, as those files are required for Perspectives to work properly (they just shouldn't be present for people NOT running Perspectives). The perspectives installer should have installed those .opt files for you as well though. If not, I would try to start by doing a repair install.
