Reiga - World map
Hello,
I've been working on a worldmap for a project that I'm keeping private for now, but I figured I'd post some early screenshots of my map to get some feedback from you guys. I'm very new with CC3+ (bought it a couple of weeks ago), so I may be doing some things wrong. All kinds of advice welcome !
The images are pretty big despite being fairly low resolution so I'll just link them rather than include them in the post. Please be patient while they load :P. You might not be able to zoom a lot in your browser due to low res, if you want higher res, I can upload them too.
Here's a view of the entire world. I fleshed out the main landmasses, but most remain empty for now. I started with two small regions which I knew were quite independent from the rest so I used them to test things out a bit, and I'm now starting to work on the rest. Latest addition is that huge mountain range in the middle, with all the rivers flowing from it.
ENTIRE WORLD MAP
Here are zoomed views of the 2 regions I have already designed. There's more or less complete, I'm just missing texts (will help making settlements more visible) and roads (haven't found how to draw nice roads yet
ideas welcome).
NORTHERN REGION
SOUTHERN REGION
What do you guys think ?
ENTIRE WORLD MAP
NORTHERN REGION
SOUTHERN REGION
Northern region: What are those features off the northwest coast? Islands, sea monsters, icebergs - difficult to see at this resolution.
I just wanted to point out, in case you weren't aware, that you aren't limited to what's available in CC3/CC3+. You can use "insert file" to add practically any graphics you want to your maps. In the final version of the Greyhawk map I made recently, every one of the 70 or so heraldic shields is actually a picture inserted by me. Just a tip that might help you out!
One suggestion? Consider placing a darker-green "contour" under the forests. The sheet effects should give it a nice edge fade to blend in with the surrounding grassland.
I hope you'll keep sharing as you go, this is a really, really nice start!
Cheers,
Hmm there's one under some forests, but not all. I thought it didn't make much of a difference, but I'm quite badly color-blind on reds and greens, so maybe there's something I don't see there :P.
ENTIRE WORLD MAP
As you can see, most of the land is still empty, even the southern part isn't finished yet, but I'd appreciate some feedback about the shape and how it looks in general.
Thanks in advance, hope you like it !
ENTIRE WORLD MAP
WORLD MAP
I'm asking becaue all of the landmarks are smooth, organic and natural, but the sea starts with geometrical angles, hard edges and a border wider than the largest river
Apart from this, a nice map. I really like the Desert de Suun with the cliffs in the north.
Regarding the cliffs, I was quite happy to find out that the cliff symbols and the chasm symbols blended very well together !
I've been working on a new version of my world map, using the Wielink style this time. Here's a link : REIGA - WORLD MAP. Please let me know what you think, and if you prefer it to the Schley version (this one).
REIGA - WORLD MAP
Also, on a side note, it was amazingly easy to add landmasses : at first I wanted to edit the initial ones by moving around nodes and adding some, but they had so many (because of fractalisation) that it was very painful. But it turns out I was just able to draw new ones on top of the existing ones, and they visually merged perfectly and seamlessly into each other, making it really easy to re-shape and extend my continents.
In the future, if you're looking to edit your landmasses, you might want to try the Edit command option that's available for many drawing tools, like the landmass tool. Check out this post for more info.
As always, thanks for sharing.
Cheers,
