That's a wonderful map - a great appliation of the Symbol Set 1 style!
Here's a few suggestions that you could try out to make it look even better - just for experimenting, I'm not sure myself they actually will:
- the (yellow?) glow on the land sheet could be an inner glow - that might represent beaches better. Make the outside current white or very light blue instead. . Is their an Edge Fade Inner effect on the desert areas? It's hard to tell. If not, you could add it, or if yes, increase its size a bit. - The main rivers are very wide all the way to their source. I'd SPLIT them into several parts and decrease their width towards the end.
Keep up the great work!
