Error with CA 232
edited April 5 in Product Questions
I have a question about CA 232. It seems like it wasn't installed correctly. The file is named CA232, but the folder is named CA 233. Could this cause problems? Can I just rename the folder? Or does this need to be fixed with a clean reinstallation?
Thanks
    edited April 5
    Don't rename anything in the Profantasy folder hierarchy, or you will break symbol and/or texture references.
    I'm checking out what you reported...
    Later: Yes, the symbol folder is indeed named CA233, but that's just a slip of the keyboard. I notice the same mistake was made in the text of the installer too. While the installer is named correctly, "CA233" appears mid way through the installation. This won't affect the style or your use of it - as long as you don't start renaming things.
    cyrionRoyal ScribeQuenten
